File Request MSI GT72s 6QE Dominator Pro G Firmware problem
Aurelio
MSI-1782
Hi
I am getting issues with my laptop, It happened first would not boot it got stuck in windows while logo.
Went in bios disabled cpu state c, after that booted up to windows desktop environment, stays on for 45 second then hangs nothing works.
Even tried to boot Linux from USB flash drive and I get message that there's a problem with firmware (micro code error) that should update it with new and hangs there too.
I have re-flashed several time to see if it would fix the problem but no luck, don't really know what else to do.
Please help me to fix
Ahmad Kor
Hi, If you need bios :
If you need technical support ask your question here :
Aurelio
Hi
My GT72S suddenly started working well after leaving overnight running with WinPE10_8_Sergei_Strelec, since it was only allowing me to boot through WinPE10.
Maybe is because does not require all the machine resource, not very sure exactly happens but is working fine and i amreplying from the same computer.
All i know was able to change my windows and able to boot with linux too.
Ahmad Kor
technical support only from here :
