test the original of my PC Dell vostro 15 3510 gdm51 la l242p rev 1.0 (a00)
its your bin file the pc no longer starts
it displays dell is its cut is the caps lock it flashes once
does not work it just gives yellow then green then white colors
no the problem is not in the hardware because the machine has the first time it displays with bios password, and there is someone who flashes the bios is it gives the same problem sa (just gives yellow then green then white colors) danc the problemcheck hardware
no the problem is not in the hardware because the machine has the first time it displays with bios password, and there is someone who flashes the bios is it gives the same problem sa (just gives yellow then green then white colors) danc the problem in the bincheck hardware
the problem in the new bin you have to clear me region for it to work well, if you want I gave the original bios bin to repairsame problem with new file means problem is not bios
helmi h , Vahab Hemmati , Seye Ordis , Salimeh Bolboli , SAQER BAKER , amalangi , Ali Shaikh , appleguys , Kanini Technology , user61858 , user24324 , s2qers2qer , SSV , rscomputer , dinesh1144 , ramamurthi
