File Request dell latitude 3520bios is not good
qkhafeez
dell latitude 3520
Hi sir
i am sending you ORG bios file with ORG file laptop dont switch on but , i have other file come out from same laptop with that file laptop switch on screen gave multi colors white blue ext , so i thing Org file need to be fix
  • XM25RH256C@SOIC16-300_20241019_143140.BIN
send motherboard model
same problem means you need to check hardware
its not seem good !
because different files have same result
you are very welcome
its ok but in 99% of times if there is same result with various files , the problem is on hardware
good luck
